SURF PI PROBLEM
  • SURF PI PROBLEM
    my supply voltage is 16 volts but as i decrease the voltage i noticed the sample pulse is not tracking the back emf curve so the sample is in the wrong position the more the voltage drops and the detector looses depth...how can i correct this so both the curve and sample pulse keep in tracking ???
    i open datasheet on tlc555... and see you use tlc555 on upper of nominal supply - Single-Supply Operation From 2 V to 15 V.
    15V is maximum for it. you use it abnormal on the risk, on edge of crash.
    loving crashtests?
      i did some more testing....if i set the sample delay at 10 uS and the supply voltage at 16v which is ok...but if i reduce the supply down to say below 12 volts then the decay curve changes and then the sample is in wrong position like in a dead zone and then no response from detector if target waived in front of coil....if i change the sample delay to 15 uS then i can still detect a target at around 12 volts....maybe the only way is to double the voltage to 32 volts and use a 16 volt regulator to the power supply.
        can someone please advise on this cause i need to solve this problem so i can reassemble my surf pi.
          u could try something like 18V lithium pack from cordless.
          Put a low drop out reg in and run it at about 15V. Most liear regs drop around a volt or less now.
          Old 7805 s used to be about 2.5V drop so needed 7.5 minimum in
            12V voltage of batt goes on IRF and tlc555 generator directly. no there reg.
              thanks kt and other guys for your help.
