what will you use if you have to detect 14-17 meters underground
  • what will you use if you have to detect 14-17 meters underground
    What to use if you have to detect underground if prediction depth is 14-17 m also is it possible to know in advance what is buried before digging conductive or not conductive target
    rock
    2m
    ------------- ground
    14-17 m ----target
    Acoustic sensing.
      miners helmet
        What size target. German train size. LOL.
        Coin size I can't thing of anything that can go anywhere that deep.
          This could do it. https://www.google.com/search?q=Indu...utf-8&oe=utf-8
            Are you looking for oil?
            Perhaps you should try some bore-equipment.
            Electronically seen high sensitive magnetometers should work if the
            surface is free of rusty iron trash and the ground not too mineralized.
            Of course only if the treasure is inside a huge iron box or other ferro-magnetical metal is nearby.
            Perhaps also a special detector works where you can place the receiver and tranmitter coils
            50m away from each other and afterwards you may get some "metal object in the middle"-signal.
            This also works with non-magnetical finds but I guess the treasure has be really huge!
            If you wanna know if something is buried inside a 20m huge hill perhaps the best bet is to
            dig a trench into the middle with an excavator or blow it up with dynamite - that way Schliemann
            got his "Troyan"-treasure in Turkey.
