I had build (homemade) metal detector but it dosen't work how it supposed to do. I can adjust pot and that works. It detects big things at max 2cm near coil. Coil is R=30cm and 27 turns and with resistance about 1.8 ohms(measured with cheap $8 multimeter in 2 wire configuration(direct from multimeter to coil)). Power supply is 12v rail of atx smps.
Here are some images: http://imgur.com/a/5WCgR I replaced TLC555 with NE555 but i think that will not cause problem. I replaced also MPSA13 with BC517. There is sound but with noise in background.
