Fortune M, Quasar ARM and KROT2 XM
  • Fortune M, Quasar ARM and KROT2 XM
    Anyone on here built one of the above. Quasar looks very popular on YouTube. Also PCB is readily available. Seem to be some using on wet sand but can't tell if its lake or sea beach.
    PCBs are very confusing no two look identical.
    I would have guessed this site would be the most up to date
    http://fandy.ucoz.org/publ/metalloiskatel_quot_kvazar_quot_quot_quasar_quot/metalloiskatel_quot_quasar_arm_quot/2-1-0-5
    But have see a vision 2 PCB for sale.
    Some of the YouTube video of them being used in the field are very funny. Never seen such big holes dug and still miss the target.
    The fortune m looks to have less false signals in the field but much less popular for some reason.
    krot2
    I built two of the krot2 xm detectors. I built the second one thinking I made a mistake on the first one because of Morse code like false signals. I went out MD-ing today with it and found a coin. It still gets false signals, but much less due to improvements in firmware. I heard that some fellow was working on a new receive section using a MCP 6022 ( like the Quasar ARM has)to replace the original MCP601 claiming that it eliminates the false signals(which is the detectors biggest drawback) I'm also seriously thinking of building a quasar ARM, but the current board designs are limited. I have a hard time drilling for vias on a board that small. A nice looking board V 2.0 is available on Ebay from some guy from Moldovia. I hate to give up on the krot2 XM, because it has good firmware support from the author Andrew, and has nice features, but at some point you got to pull the plug. I have problems trying to de-cipher the Russian forums. I have heard some good things about the Fortune M but I have no experience with it.
      Quasar ARM vs Fortuna
        Signum 7272M vs Quasar ARM vs Fortuna M
          Quasar ARM vs Krot-2XM vs Spektr
            Thanks for the feedback
            Seen a lot of videos with them suffer from false signals. Hard to tell from YouTube as you don't know how bad the ground is.
            A search on here shows a few boards for the quasar were bought but can't see any finished detectors.
            Google translator does a good job but somehow technical forums the meaning often gets lost.
              Krot-2XM
                Hi KT315, in your videos if you can understand Russian, does the guy in the video arrive at any conclusions regarding Mole VS Quasar VS Fortune M?
                  Wiltran, dear friend. I do NOT make here an adwertizing of the DIY projects and do not do a profit on them like someone with nokta.
                  I give you INFORMATION from one part of world for your part of world.
                  its only on your choice and taste. if you pay for $5000 price nokta detector so why you ask me to choice a hotdog at street sale???
                  you pay NOTHING now, HEX code is free and if you will pay small money to an author so he will go on here and
                  say MORE than I speak now to you. BELIEVE me. so accept the info from me as it is - too stingy and without report.
                  Mole Quasar Fortune etc did not come on from nothing, these guys did learn schematics from Geotech, experimented
                  with analog detectors before - Whites, Tesoro etc.
                  free hotdog, with coffee, from me, to everybody. no money please! no money Sir!
                    finds with Fortuna-M
                      kt315 - I think Wiltran is simply asking if the man in the video said which one he thought was the best ... Mole or Quasar or Fortune M?
                      He's asking you because you understand Russian, and he does not.
                        Fortuna-M. a test of block. no coil, he touchs the connector and generates a sound reply.
                          ok. in first video a tester says at end that he would like to see some mix, a sound and grafo taken from Fortuna but the depth taken
                          from Quasar.
                            Thank you kt315
                              Google translate makes a good job with this site. Gives an idea of the menu options.
                              https://translate.googleusercontent.com/translate_c?depth=1&hl=en&ie=UTF8&prev=_t&rurl=tra nslate.google.com&sl=auto&tl=en&u=http://metallo-iskatel.ru/&usg=ALkJrhg3o4CUcT4myYhtexmf7HTWcw9SYQ
