Has anyone got a schematic of the audio section of the gold scan 5....also i noticed there is a mod for a switch for high & low or all tones...how is this mod done ????
gold scan 5 audio
If you want to add a simplified hi/low conductor switch that acts much like the one on the TDI, you can do what I did on the original GS 5 and that is, add a 2 position switch, center off type. Center leg will connect to the GND connector on the audio board (blue wire on the pic). The two ends of the switch will have a wire that will also go to the audio board and connect as shown in the attached pic. The two wires are a white and a yellow and each will connect to a resistor being careful there is no shorting to other parts.
RegAttached Files
for change of tone of VCO you can change ANY value of R and C, it is rule.
but GS5 sound is not same like GS4. GS4 sound is fully similar to Delta Pulse sound (how i see in youtube).
gs5 sound -
https://www.youtube.com/watch?v=QhNrIENbwJE
It's hard to get beautiful audio VCO from worst detectors you get very good detectors
https://www.youtube.com/watch?v=F3-yro41Fek gs 4
https://www.youtube.com/watch?v=QhNrIENbwJE gs 5
https://www.youtube.com/watch?v=7rTA2CH_x8Y Tdi Whites
This topic is very interesting audio GS5.
I suspect it is also known to some forum members, but remains reserved.
Mickstv, public something similar in "full Tinkerer project", The scheme is in the link below, but now you can not see the scheme.
From GS5 scheme published in Geotech and the published audio by Mickstv, it could be performed much like the GS5, with audio tone, similar to TDI.
As orbit says, it is difficult, but not impossible.
http://www.geotech1.com/forums/showt...914#post178914
Of course it is possible !
https://www.youtube.com/watch?v=4GG-j5uKDTU
I think I know to which scheme thoughts Jose I tried but I did this solution for one reason but it does not matter who .
Originally posted by Reg View PostIf you want to add a simplified hi/low conductor switch that acts much like the one on the TDI, you can do what I did on the original GS 5 and that is, add a 2 position switch, center off type. Center leg will connect to the GND connector on the audio board (blue wire on the pic). The two ends of the switch will have a wire that will also go to the audio board and connect as shown in the attached pic. The two wires are a white and a yellow and each will connect to a resistor being careful there is no shorting to other parts.
Reg
http://www.analog.com/media/en/techn...eets/AD654.pdf
Originally posted by greylourie View PostThanks for posting, Reg. The image shows an AD654. A quick look at the datasheet states its a voltage to frequency converter that outputs a square wave at up to 500kHz.
