Russian Pulse metal detector
  • Russian Pulse metal detector
    Found this on the net, has some interesting ideas, needs to be read carefully.
    Russian Pulse metal detector.
    https://shema.info/en/consumer-elect...-detector.html
    no matter how interesting the project, the results are:
    - coin diameter 25 mm - 20 cm
    - the gun - 40 cm
    - helmet - 60 cm
    nothing more than what you give Clone Pi, Barracuda, Surf Pi or Sandbanks and other.
    It is essentially a scheme Tracker Pi by authors A. I. Shchedrin and Kolokolov -
    commercial project whose software is not distributed freely.
      that is Tracker, Koschej 5I/5IM, Clone. discussed much times and in much threads. do not see neccesity to open still one new thread.
      no something fantastic. initially was strong commercial KIT because you have to buy programmed u-chip.
      then Andy Fiodorov did make and shared open code.
      CLONE PI is OPEN CODE, YOUR LINK ABOVE is CLOSED COMMERCIALIZED CODE. choice from both.
