£12.67 oscilloscope any use
Wish I had it last year. Fixing a car running on 3 cylinders turned out to be a bent pin on the ECU. Thought about fetch the scope down but sorting tables and mains leads. This on a battery pack would have been ideal.
Display is too small for measurements. Fine if you display the measurements. Frequency is spot on but peak to peak has a difference .2 volts with my other scope which one is correct I don't know.
