PD 3200 - STINGER
  • #31
    Drawn from the author PD 3200 so that it did not invent only from Orcad transferred Sprint Layout !
    Otherwise pcb's good have a nice protection as if they're making somewhere next door!
    A little advertising is not wrong ! What is it Feljzo Is that truffle ?
    That in your language is Feljzo may mean truffle.
    But as I wrote FelezJoo_PI, the name of the metal detector.
    http://www.geotech1.com/forums/showt...light=FelezJoo
    • #32
      Originally posted by mikipn View Post
      Hello Sneshko
      I can not put the hex file on the forum.
      I want to send atmega8 with written a hex file to your home address.
      The PCB, which has the forum, drawn in the same LAYOUT50 not accurate.
      I want to send you and one PCB. Of course you're just gonna pay me, how much I cost.
      This applies to all colleagues at the forum, which wants to have a piece for yourself.
      I'm interested in these days with FelezJoo_PI. I moved I counter. If you want to know I want you to send and ATMEGA328P with written hex without counter.
      [ATTACH]36097[/ATTACH]
      Thanks for reply mikipn!
      I'm interested in your offer.
      What size (dimensions) coils can use metal detector PD3200?
      I have not had the opportunity until now to try Metal Detector PD3200th.
      On its original Web site does not state that the coils uses this Detector.
      Thank you in advance for your reply.
      Regards!
      Sneshko
      • #33
        Feljizoo hha I have long played games for children Feljizoo pi http://igrezadecu.com/cars/
        • #34
          Regards!
          Sneshko
          I made coil, 35x55cm, 1x1m, 2x2m
          • #35
            Thanks!
            I'll send a letter to your PP.
            Regards!
            Sneshko
            • #36
              whether it is good this way.
              [ATTACH]36099[/ATTACH]
              [ATTACH]36100[/ATTACH]
              Thanks.
              • #37
                It is this, I've made.
                http://metaldetector.com.mk/mole-impulse-digital
                https://www.youtube.com/watch?v=KFNMPWvHu6Y
                • #38
                  Details Depth up to 8 meters!
                  On what target ?
                  • #39
                    on russian kv5 tank
                    • #40
                      Miki copied better than the Chinese chinese young children, Beware danger !Mole Impulse that is so good would be more appreciated in Bulgaria I know a lot of Bulgarian seeker no one mentions !
                      • #41
                        If pd3200 is not good, why are you at the beginning of the topics that you are open, you are claiming the opposite. That is good and that there is discrimination. and then you put some data that do not have anything of pd3200.
                        Are the video film that you set, you made the video.
                        • #42
                          I'm talking about Impuls Mole which he a real Petar Vlcev not you !
                          I did not do built by this video did not say that my where I wrote ? And you did not not invent it you just copy it far as I know you just know that i you are not you are not alone constructed ,just copy it other people's projects ! I know I'm the first vlf detector you got from me who have a problem ?
                          Nemam nameru da se sa tobom ni svadjam ni prepirem lose si utripovao stvari tako da nemoj da pomislis da hocu nesto negativno da te promovisem malo sam te bocnuo jer te nigde nema sta se ljutis ko mlada .
                          • #43
                            I am also sounded the theme pd3200. I did not write I invent a new detector. I do not see what the problem is. Who made and who invented pd3200, I do not care. I'm just saying that I was making these detectors more pieces and I showed the video movie.
                            Ja nisam imao nameru sa vama a ni sa bilo kim da se prepirem ovde na forumu. Ja sam posle mozda mesec dana pogledao na forum, i ugledao temu PD3200. Zato sto imam napravljen pd320 ja sam pokusao da napisem hex koji si ti postavio, i tada sam video da to ne radi. Onda sam napisao istinu da ljudi ne prave nesto sto ne radi. I tada ste Vi rekli, kako ja nisam nikakav programer i slicno. Poceli ste mene da vredjate, uvek sam odgovorio sa dokazima preko fotografije i to bez ikakve uvrede na vase ime.
                            translation
                            I did not mean with you and not with anyone to argue here now. I am after maybe a month at the forum, and saw the subject PD3200. Because I have made pd320 I tried to write the hex that you set, and then I saw that it does not work. Then I wrote the truth that people do not make something that does not work. And then you said, that I'm not a programmer, and the like. You started insulting me, I always answered with evidence through photographs and no offense to your name.
                            • #44
                              I think I hurt because that I appointed as the theme 3200 , I know that you are not a devout .
                              • #45
                                Demo hex file, which works properly.
                                https://youtu.be/Y_KapJzJHMM
