I want to build a simple TX coil driver using a DAC followed by an amplifier for a VLF IB detector. However I'm not sure how much current an average IB metal detector puts through the coil.
What I intend to use is a either a headphone amplifier or a small loudspeaker amplifier (single-ended or bridge-tied-load).
System parameters:
TX inductance: 0.95mH
TX resistance @ DC: 4.3 Ohm
TX capacitance: 150nF
TX tank type: Series RLC
TX tank resonance: ~13.33kHz
DAC Output voltage: 0..1Vrms (2.8Vpp)
Supply Voltage: +5V / +3.3V
The low resistance of the TX coil causes me some headache because most headphone/small speaker amplifiers are only specified for 8/16 Ohm loads.
My question boils down to how much power / current does the amplifier need to deliver
System parameters:
