To start the ball rolling, here is a linear plot of a 3.5gm thin wedding band. A ring gives a virtually pure single exponential and all the plot numbers join up nicely.
Compare this with a US Nickel which is often used as a test target. In this plot you can see that the first three numbers deviate from the exponential and only from then on does the plot fit.
This is the effect of a solid centre which has the effect at early times of giving a faster initial decay; some call it a type of skin effect, others refer to it as diffusion. This behaviour is very evident in good conductors such as silver coins of which I will post some plots in due course.
The previous plots on the Vallon thread for 4mm square copper foil suffer from lack of data points as the lowest increment on my measuring instrument is 10uS. The instrument was designed for magnetic soil measurement where the signal decay persists for much longer. However, it can provide useful information on rings, coins, and all but the smallest gold nuggets.
The graph plotting is fairly basic but does provide a quick, hopefully accurate, and noise free, picture of the decay, although I agree that there seems to be a problem with the scaling of log plots. I will have a look at that.
Eric.
Eric.
