DBP2010
  • DBP2010
    Has anybody any experience in fine-tuning the DBP 2010 ? Kees
    Re: DBP2010
    Hello,
    There is a french forum discussion about a book where DBP2010 is described.
    http://fr.groups.yahoo.com/group/ddm-elektor/
    This book is a french translation of a original German one, who provide very good information about metal hunting.
    One guy seems to got excellent results with this detector, and explain problem encountered, adjustment, coil winding etc ...
    Michel
      Re: DBP2010
      I built two DBP2010 dete3ctors . In the book however there is nothing said about adjusting the detector . Still works pretty good as it is though .I would like to adjust to specifications and those are not given in the book . The book is written so you will buy the kit from the designer and that is not the right idea if you ask me . Kees
        Re: DBP2010
        Hi Pruyser
        I have the German version of the book. The guide line how to adjust the detector start at page 170 to 174. Which language version do you have? French, Dutch, English or German? Should I send you the German version?
        Chris
          Re: DBP2010
          I agree with you and as components are not specifics, kit package has not a real interrest.
          I did'nt built it, I have built PI-1 because it is widely open to experiment.
          I have also a Digger on my table, which is absolutely unusable without an updated software.
          If you have "The book", did you compare Tesoro Bandido schematic, recently published, and diagrams A1-A2 on pages 150 and 151 (french version)?
          Michel
            Re: DBP2010
            Answer :
            Schematic A2 is a tresoro Eldorado ;o)
            hoooowwww you win !!!!!
            I have the book in french .
            There is a little mistake on the placement of the component drawing 3.35 page 130 ( french version):
            between the two pads near P1 and P2 there is wire : you can see it on the drawing 3.34 page 128 french version).
            PhilippeM
              Re: DBP2010
              Chris . I have the Dutch versian of the book . There is some info on starting the detector but that is not what I am looking for . I don't think there is a proper adjustment written by the designer . Kees
                Re: DBP2010
                I was reading a forum on mods, and think you have a french book about and tesoro eldorado. I need a little help...I noticed that there are 3 test point on the PCB, and a small trim-pot. can you tell me what check can be made using the test points, and the trim-pot?
                thanks.
                ejf
