X5 Shadow coil connector
  • X5 Shadow coil connector
    Hi everybody
    does someone know the pinout of the Shadow X5 coil connector?
    Chris
    Re: X5 Shadow coil connector
    Purely from memory, from measuring them yesterday...
    The two outer pins closest together are TX.
    The other two outer pins are RX.
    The middle pin is not used.
    I could have TX & RX reversed. Typically, RX coils have more windings, and therefore higher resistance. So you can use an ohmmeter to figure it out.
    When I get home, I can reverify.
      Thanks Carl
        I had it backwards after all. Pins 1 & 2 are the RX, about 85 ohms. Pins 3 & 4 are TX, about 15 ohms. Pin 5 is no connect.
