swap the edge of the potentiometer output
Magnum on steroids!
Originally posted by reiv View PostThank You for answer. But if i swap ("1" and "3") ground with -5v of the potentiometer i get no control volume at all. That is why I don't understand this.
Firstly I would check that the pot is actually connected between 0V and -5V, and that one end is not floating.
Secondly I would check that Q2 is a PNP transistor, and it is inserted correctly, bearing in mind that the same transistor can sometimes have different pinouts.
Also, try disconnecting the wire to the centre pin of the volume control (R26), and measure that the voltage at that pin can be adjusted from 0V to -5V. That will confirm the pot is OK.
Nikko10 I have a question if You don`t mind. In this PCB ver.1 wich have You posted earlier there is more errors? Besides of BG, Volume pots and label 10nF ? I have major problem with discrimination- don`t work at all...All signals phase shifter works, but it don`t discriminate any metals.
Hi, please help me. I'm reaping of all my hairs beacuse of this circut. Maybe someone can answer how does it possible to not working discrimonation in one tone mode ?? If I switch to 2 tone mode all works fine, foil is discriminating if turnbthe nob etc. But in one tone mode beeps the same at any kind of metal, no reaction at disc. pot. I tried to switch 358, 393, 4053, zener and 4148. Even if I desolder 3v3 zener, 4148,1m5 behind comparator 393 it beebs at metal with no discr. I don't understand this circut.
