Magnum on steroids!
  • #61
    [QUOTE = From the model "1+" up to the model "4WD" it is all the same pcb.
    Except for some components added or removed from the pcb and front panel.
    Some front panel commands are "locked" with fixed presets inside the model "1+",
    while the same ones are presented on the front panel on model "4WD".
    According to this you may anticipate the rest of missing components.
    For example, for changing TX frequency between 8 and 18kHz, you need to add
    switch and two non polarized capacitors: 100nF and 470nF.
    "Auto GEB" is fixed preset inside with trimmer and "Manual" is with potentiometer mounted on front panel.
    Another switch is just switching between them.
    P.S.
    This is nothing new. This is quite old "practice" already seen at some manufacturers in the past.
    First what comes to my mind is the case of Minelab Musketeers: Colt, XS, Advantage...
    Pretty similar story...
    [/ QUOTE]
    Thank you ivconic
    You'll show you how to connect all options
    Auto GB and maunal and two tones
    • #62
      No development for part list
      • #63
        Can anyone make gerber files available? I don't own a copy of sprint. Thanks!
        • #64
          Is this enough?
          • #65
            Mechanism to attach files works very slowly!
            • #66
              And here is the third PCB.
              • #67
                Thanks a lot Toros!
                • #68
                  Okay, another question. Which program do I need for the sch files? I have tried splan viewer, P-CAD sch viewer and EAGLE. Neither of them work...
                  • #69
                    I read some .6 program version files will not open .7 version files and so forth. Might be the problem.
                    You can also try
                    http://www.file-extensions.org/sch-file-extension
                    • #70
                      Look for Express SCH. This program is author's favorite .
                      • #71
                        Yes it is done in ExpressSch, part of ExpressPCB package.
                        http://www.expresspcb.com
                        • #72
                          Is the thpcb throughhole board the same as the one shown in the video with two tones? I think I'm getting this confused with the Goldenmask info.
                          • #73
                            That's exactly the same board.
                            • #74
                              http://bestmetaldetectors.eu/metal-d...eadphones.html
                              • #75
