Magnum on steroids!
  • pcb1_2.zip
    Here are the final files i sent to China:
    Your files are correct,Let's still be checked and writing here for no extra cost
    • Originally posted by bandito View Post
      [ATTACH]37982[/ATTACH]
      Those gerbers are directly exported from the Sprint Layout file i posted earlier.
      They must be 100% identical.
      Only problem was because i used green layer as top and blue as bottom in Sprint Layout.
      In gerbers those are irrelevant, because you can rename it anyway you want.
      • there are different Gerber file extension but much popular
        для слоя Top - top GTL
        для слоя Bottom - bot GBL
        для слоя Top Mask - smt GTS
        для слоя Bottom Mask - smb GBS
        для слоя Top Silk - sst GTO
        для слоя Bottom Silk - ssb GBO
        для слоя Top Paste - spt
        для слоя Bottom Paste - spb
        для слоя Board - brd GBR
        Layer
        GTO Top Silkscreen (text)
        GTS Top Soldermask (the 'green' stuff)
        GTL Top Copper (conducting layer)
        GBL Bottom Copper
        GBS Bottom Soldermask
        GBO Bottom Silkscreen
        GML/GKO/GBR* Board Outline*
        TXT Routing and Drill (the holes and slots)
          Ok I see what happened to my boards when I converted the Sprint File to Gerber. I took a good look at your orig Sprint. Then compared my Gerber conversion to yours.
          When looking at your Gerber files, there were two files that were blank files when I opened those up in Gerber viewer. Are these files actually blank or am I doing something wrong?
Name:	Screenshot from 2016-11-30 23:09:04.png
          Considering having new PCB's made, just want to make sure I have correct Gerbers.
          • Yes those are probably empty fies, generated by SL exporter.
            When i exported; i marked all the fields respectively and exported all possible layers, even the ones which are not used.
            I don't know why is this gerber related thing so confusing? Things are very simple actually.
            In Sprint Layout when you draw your pcb, it is not really important to "obey the rules" at all , in case you intend to export draw in gerber format later.
            Because you will export each layer separately. So, drawing on a layer will always remain the same.
            You only need to pay attention on whether to export it mirrored or not.
            If you picked the "wrong" colors in SL for layers; later on you will need only to mirror those when exporting and that's all.
            Also you can rename gerber files if needed.
            When contacting with Elcrow, they returned me back files to correct them and fix the clearance only.
            But it was never a confusion about layers though.
            They knew which layer goes to top and which one goes to bottom, even without me pointing on that.
            You can always import gerber files back to SL to check them.
            I admit; i did a sloppy work when i haven't payed attention on the "rules" in SL.
            I use SL because of the ease and simplicity, but later on those draws must be converted to gerber if plan is to manufacture them by professionals.
              Your zip file is still missing this file
              • Originally posted by SVEN1 View Post
                [ATTACH]38002[/ATTACH]
                Yes because i didn't want to send that to China.
                You don't want to see those detectors with label "Made in China" very next morning on Alibaba, right?
                • Comment
                  • Ivconic,
                    However error Layers PCB is yours. I think you owe Sven least one true board as compensation.
                    • Originally posted by Toros View Post
                      Ivconic,
                      Fair.
                      Next time i make a batch i will offer him pcb.
                      • I already placed an order with ELECROW using Ivonics latest files he sent to China. Giving it one more shot.
                        • Corrected PCB's arrived today. Hopefully next week I will get to work on one.
                            Good luck to you. We are waiting for the results.
                            • Great!This thing just ain't for nothingClick image for larger version
                              • New boards
