Magnum on steroids!
I will not argue, just lay out for those who wish - the board is fully working, collected by all and all ....
link to google drive https://drive.google.com/drive/folde...lNsa3dMVU9BLU0
and link to psbway https://www.pcbway.com/project/share..._Detector.html
Please who should take it)
Hi all,
Such a problem arose - the comparator threshold does not change when the R35 trimmer is rotated along its entire end-to-end range.
All voltages are normal, all parts are brand new (nevertheless they are re-measured before installation).
In general detector works but not so deeply (10-15 centimeterс fор medium size coin). For non-ferrous discrimination works ok, but but the iron
is discriminated across the entire adjustment range of the potentiometer "DISK". It seems that both problems are interrelated?
Thank`s in advance for any ideas анд tips for dealing with the problem.
Greetings to all . I made this detector, but I have a small question .The board is SMD, not redu - full variant 2 4053 . Discrimination is normal, distance is about 30-32 cm 1 euro coin .The coill is 26 cm with suitable inductance.
But there is something like a skin effect , when touches the cable or housing MD this gives false signals . Not yet tested in the field.
Is this normal in the building ?
