Hi everyone,
I want to build a simple metal detector for my 4 years old kid. I made once a BFO detector that works not so bad but you have to adjust the
coil manualy during the use.
I found on the scheme section a PLL detector with NE556 but the only PLL i have in my electronic stock is a MC14046. I found the scheme on the net :
Does someone has already build it ?
I have few question on this scheme :
1st : The frequency tuning cap should be connected to pin 6 and 7 and not to ground on 7 (green point on the scheme) ? On the datasheet, there is no ground to the cap.
2nd : The VSS pin should be connected to ground directly and it's cabled to ground by a 1.5µf cap, i don't understand this fuctionning.
This scheme is hard to read cause the crossing are not clear, there is no point to show the connection between several wires.
I also join my lay file ..iwan PLL.zip
