Hi I am a novice at technical things, and it has been suggested more than once that I not touch the things because I eventually break them.
but this is the second excalibur I have owned and I have opened and sucessfully reconnected the coil wire and fixed the battery wire and identified shorts in the cable and have installed the "water proof" connectors and have had to re-do the connections several times.
due to water leakage. so I have been able to so some things with out sending it for repair.
but I
recently open the case and had the board on the table with the headphones connected and on my head , as I turned my head, the board moved and my pliers contacted the bottom of the board and then it didn't work any more.
I purchased some of the capacitors that are near the coil connection and are accessable to be taken off thinking that it couldn't hurt to try some inexpensive things to try to get it runnign again so I got them and reinsatlled them,
there was no improvement. infact there is no response at all,
even with the short it would give a clicking or pop when I turned it on and off
but now is just silent.
I tested the voltage at the battery wires going into the board and it would get the same voltage when turned on as it would when turned off ( about 12 volts)
now after the new capicitors, it gets 12 volts before I turn it on, and it gets only 1 to 1.5 volts when I turn it on and there is no sound at all
Minelab quoted $350 for new board, but this is at least 6 years old and I would like to find a good used board or find some one who can diagnose and repair this one.
if you can find a used motor for a car, why can't you find a used "motor" for this thing?
any one have expereince (more successfull than mine) on repairing Excal boards #3069
photo shows the new cpacitors after intallation, I purchased them from mouser and odered the same specifications as the old ones ,
repalced resistor next to battery cables (15404)
and put the white stripe on resistor the same direction as the white stripe on board
the two on top are c5 and c5A on board replaced
two 470 uF 16v with 105 degree temp
but the two on the bottom board said H8 and H9 from sanwa and corresponed with a c38 and c39 on the board , the specifications are the same, but I could not order from the sanwa web page because it is in Korean so I couldnt' get the info on if there are any differences between the H8 and H9 capacitors
does the H8 and H9 have any differences if the spceifications are the same?? 1000uF 16 v
thank you for any help or suggestions
Bert
