Hello guys,
I made a PI metal detector based on a cheap stm32 board and the result is just fantastic. It totally outperforms my Whites dual field detector and many other. It works really stable even on some hard soils(Not Australian soil, but still a pretty nasty soil). I would like to share the schematics, PCB and the source code with you. I'm sure many people will appreciate it as it is easy to build, cheap and powerful detector. The problem is I don't want to have problems with some detector manufacturers. This is why before sharing the project I would like to ask you if I am using some patented technology?
I saw several ML patents(For instance THIS one, but there are several more) on digital signal processing and they are describing signal processing and GB technique. I don't understand the whole document as my english is very bad, but it really looks similar to the way my detector is working. Do you think I can share my design without any problems?
- My detector is processing the signal directly from the op-amp's out.
- It uses well known digital filters to filter and average the signal. Also oversampling and decimation.
- Here comes the part which I'm afraid may cause some problems - It has GB option based on the Eric Foster GB method with three(or more) samples. The GB works by single click on a button. No need to manually set the balance.
- It has a color tft display showing all the settings, signal level and basic information about the target conductivity.
- It has 3 different audio modes.
- Two different color themes.
- Works in static or dynamic mode. User can control the SAT speed.
- User can change the TX width and frequency.
- User interface is done by one rotary encoder and 4 buttons.
