PI how to increase range?
  • PI how to increase range?
    I am using PI basic circuit only RL with clamping diodes with R before and I make an ARDUINO comparator and I start counter till the comparator signal changes, I compare the voltage from clamping diodes and compare it with pot voltage in mv. It gets 12 cm range for a metal object 10 cm 10 cm plate.
    QUESTIONS:
    I want to increase the range to 40 or 35 cm? what can I do?
    When I use OPAMP lm318, the voltage varies from 2 volt to 4 volt, but arduino gives data than my avometer.why is that?
    I have lm318 lm358 tl072 and I have 30 boost converter. I have pic12f675 with 20MHZ crystal
    thanks in advance.
    Measures that increase range for all objects:
    Earlier sampling.
    achieved by:
    induction balanced coil,
    high bandwith amplifiers
    Noise reduction
    achieved by:
    lower resistance values in the amplifier chain
    low noise amplifiers
    earlier sampling
    signal averaging
    For targets with long time constants.
    On-time samplng
    Just off the top of my head.
      Are you measuring voltage or pulse width ?
      Are you sampling the voltage with a fixed delay after the TX pulse ?
      I have built several detectors that measure the flyback puls width. Depending on the resolution of the timer (16 bit? - of which 10 toggle with a pulse width of 100 micros ? ) you should be able to get at least 30 cm on a 10x10 cm (iron ? ) plate.
      Increasing the coil size will also get you more depth, but less sensitivity for smaller objects.
      If you are measuring pulse width with a comparator ( aka temporal sampling), you might have a look at my Pickini project here:
      http://www.geotech1.com/forums/showthread.php?23400-PICKINI-V4-an-easy-to-build-self-adjusting-PI-detector
        I am measuring pulse width using a counter not an interrupt as there is no other routines to do[while(!comparator) counter++;].
        but when i try to use ADC, it is very noisy.
        when I use OPAMP it doesn't work in either methods.
        And I am using a fixed time delay 5us.
