New Greek PI detector.
    Thanks TIM
      Maybe the new Greek detector is an upgraded Superscan, which has been made in Greece for some years. The control box looks downsized so I guess modern batteries have been used rather than the lead acid gel ones used in the Superscan. Does anyone know the name of the company which makes the new detector?
      Eric.
      Hi Eric.
      The company name is MPROS1 and the site is http://www.mpros.eu/en/.
        Power-Delay-Thresh-Filter-Adj manual-Adjust-Audio. An auto/manual switch and auto reset button. A 24V Delta Pulse...???
          for what 24V?? if you want more depth (more TX power in coil) you have to increase PULSE WIDTH but not the power supply voltage. DP has 500us max, its enough, you can
          increase to 1000us and get Eric Foster's Aquapulse towed 1000uS. though with this width i deeply DOUBT its useful on the soil. Aquapulse towed 1000uS was used only for ocean/water environ, not for soil.
            http://www.docfoc.com/delta-pulse-me...ractical-guide
            thank you again for the mention of my alias in arabic context.
              "If it looks like a duck, swims like a duck, and quacks like a duck" ... probably we can assume it's not a pig!
              "Filter Knob" is probably "Gain" Pot in Delta Pulse because when you can call it a "Filter" - when turned down (lowest resistance) it has more chatter and and noise,
              and again if you increase it (higher resistance) you get less noise and less sensitivity..
              Delta Pulse is pretty much tapped out in terms of improvements. In my last DP build I've removed 556, 4538 (both) and associated parts and placed a MCU
              and still it's Delta Pulse so... the one thing that can be looked is the Autotune/SAT section which I doubt anyone understands how it works so... I'm willing to throw a bet it's what we say it is = Good Old Delta with new name & fancy Voltage meter on the front panel
                This is the winnerClick image for larger version
                  Yes very good KT and Orbit. Yes Eclipse Autotune/SAT could be a bit quicker (or adjustable). I think Benhams document mentions how to speed up response time. These would be useful improvements for KT Marauder v.? maybe...
                  Perhaps experimenting with components/settings could eventually warrant 24v...Or perhaps it is just +/- 12v ?
                    I buy as much as I can from Greece to help their economy defeat the fascist and undemocratic eu (ok political rant over) so I will be buying one on these ASAP.
                      Right move Sean. I would buying rather their extra virgin olive oil, feta cheese and retsina wine.
                        You and I have similar tastes. At this very moment I have 8 litres of olive oil, crushed olives, houlomi cheese and retsina wine on its way from Cyprus (the Greek half). The olive oil is made by the nuns in a monastry in Limassol and it is far nicer than the best we can get in our local shops. The olives are grown by a detector friend I have known for many years, also in Limassol. My friend lost a lot of money when the government in Cyprus raided bank accounts a few year back.
                        Eric.
                          My Sniffer, from Sinko aka Crazytech, one sided design, will detect an aluminium can at 1.2M (air test) with only a 30x45cm coil (3 flat winds cat5, tapped at wind 22, last 2 winds shielding). You should be able to adjust your components/coil to achieve this Foinikas. Check it against KT schematic and others. Or maybe KT has some boards for sale??
                          I don't know anything about electronics, my main source of information about metal detectors is geotech and the opinion of the experts.
                          I have spend lots of hours reading in this forum to get some of the basic knowledge about metal detectors and their capabilities.
                          Please don't judge me from a post that was posted to be reviewed as a Spammer,if i wanted to create spam or promote a metal detector i know where the Thread about Free Advertising is.
                          Im sorry if i have violated any of the forum rules.
                          Sakis.
                          Ps. Forgive me if i have misspell something, my english isnt flued.
                          This forum btw is the reason i havent changed my Sniffer xr71p for something more expensive (eg. Lorenz).
                            Sakis.
                            Don't worry about it.
                            I was surprised to see it was a recently uploaded video
                            Saw an almost identical one years ago.
                              ... olive oil, crushed olives, houlomi cheese and retsina wine on its way from Cyprus (the Greek half). ...
                              Eric.
                              Following by sirtaki (after retsina) of course:
                              https://youtu.be/K8Li-IkbdgI
                                Nah,thats famous but not good enough for after 1 kilo of wine.
                                After some drinks you go like this https://www.youtube.com/watch?v=wjgSNs6i37c
