Clone Pi-w tuning
  • Clone Pi-w tuning
    Good day all,
    Just build clone pi W but its always yell every time touch the ground, already follow tune setup:
    "Setting MD Clone PI-W
    Setting The appliance is in balancing operational amplifier TL074 trimmer R7. This is done as follows. A coil positioned in the air to around the conductor there was nothing (no metals, electrolytes, superconductors, etc.) Expose the minimum value of the barrier (buttons) Rotate the trimmer R7 until the appliance starts to yell and slightly turn back (machine should be at the same time silence) This metal detector setting can be considered complete. More, this trimmer has never touched, and "ground balance" carry adjustable barrier. There is an easier way to set up: include the device in the air, then put the coil on the ground and immediately expose the barrier 3 or 4. We turn the resistor until the sound, and then a little back (to the sound disappeared). All! Hit the reset button and work." (From russian translation)
    But it always ringing on ground, anyone have experience with?
    clone_pi_w.rar
    Using firmware 1.2.4
    Hi, ripsdevala
    I can't download a hex file from torrent, maybe you could help? And maybe you know where I can find c source program?
      You can ask the author for c code
      For hex you can download from here
      http://fandy.hut2.ru/ClonePI_W.htm
      All non motion detector is not full working on vulcanic area like in my place, always ringing when touch the ground, maybe you can make it to a non motion detector, that would be great.
        Ok, how can I contact him?
        from the link I download a zip file, but I can't download the torrent file. I've tried all the versions...
        I am studying in college. My exam work about metal detector and i have to choose one of them and for this reason i really need c source code. Please help
        thank you, Ignas
          Try use pickini v.4 by mr.bernard, he have complete hex and source code here.
            Where I can find it?
              http://www.geotech1.com/forums/showt...hlight=Pickini
                thank you, ripsdevala
