Surp pi 1.2 survey
  • Surp pi 1.2 survey
    Hello guys! What detection distance you got with the surf pi 1.2..??
    I just made surf pi 1.2. I use 20cm doble planar coil, 25cm basket wave coil, and 27cm basket coil. All coil are ranging .8-1 ohm, 300-360uH inductance. All are similar i just get 20-25 cm detection distance on most ring size target, quiet far from the barracuda..
    And what material is Said Ring Size object made from ? Sounds like you need to Rework your Delay and Damping to me.
      I test a 8.5 silver ring and only got 9" with a fading signal and a same size gold ring 7.5" at fading signal.. i already adjusted the delay and daming for the best detection without ringing.
