I just obtained a bunch of parts that I will hopefully be able to resurrect into a working Excal II. Some of the issues/questions:
1) Koss yellow headphones cable is trash (but headphones work). Looks like the output is AC coupled by 1M resistor to ground and a series cap to the phones - embedded in the endcap. Is this standard?
2) I was thinking of putting a CTX headphone jack here so I could try different phones eventually. I'd like ideas for the headphone cable if you've had experience with this... Does someone sell the endcap or do I make my own - perhaps out of this one... Is the coil cable a must-have? I remember seeing the Peltor mod videos - but don't remember if they used a new cable.
3) Coil may not work as the bottom has cracks and water could have come in and trashed something. Haven't looked into this yet. Say its good, what should I fill the cracks with? I was then thinking of coating the bottom with truck bed coating(?)
4) The area around the battery connection on the pcb is corroded. The corrosion damaged some of the ground fill and a trace or two. What do you do to protect the exposed copper - coat with solder then what?
Epoxy, CA, some special conformal coating gook?
5) I'm going to look into waterproof jacks for headphones, coil, and battery but if you have suggestions please post.
6) Battery pod says for shallow water only. Was one for deep and another for shallow? This says Alkaline cells and has a bizarre connector. I want to go Lipoly when I get to it.
More questions to follow, I'm sure...
