Recent Discovery
  • Recent Discovery
    Recent discovery of the conductivity switch on my White's TDI SL.
    The video shows what I've found.
    It also works the same with the 7 1/2" dual field coil.
    Just the opposite happens if you run the machine with the conductivity switch to high, low conductors are also heard.
    More information to follow......
    https://www.youtube.com/watch?v=D6KEe3liOtY
    Rotate the coin on edge and pass it over the coil. The time constant of the coin is a lot lower on edge. (My guess)Passing the coil edge flat is the same as center on edge.
