Originally posted by roderico
Reading your datasheet I can think you are using a chinese bulk 1602A.
It is possible to found them in ebay at very low price.
If you do a search in internet then you can found also this datasheet for the same LCD!
LCDD-01-datasheet.pdf
Therefore, are you sure that you are reading the right datasheet?
There is printed a brand name on PCB?
If you are not sure at 100%, it is better to use this datasheet.
Going to page 11, 12, 13 and 14 you can found many informations.
The voltage and current of backlight led are different and they depends from colours and not only.
Using 5V without a resistor, also of some ohm, instead of 4,2V or less, can work the same but you risk to damage the led.
1602A Yellow/Green array LCD has 4,2V with 100mA led,
1602A White/Blue edge LCD has 3,4V with 20mA led,
1602A Yellow/Green edge LCD has 3,9V with 20mA.
To beginners:
Who don't know the led then it is better to start from a bigger value and after reduce it, if the light is low.
It is not important to rise the maximum light, if the luminous intensity is enough you reduce the battery consumption
