This unit since day one on construction has had a low main speaker volume. The phone jack that has a 470 ohm resister in series has sufficient volume.
Checked through the schemeatic and tested all wires and speaker and found it is correctly setup.
Was there possibly an omission to the schematic or perhaps a fix to this.
I am posing to add a 470ohm resister inseries to the main speaker to determine if this brings up the volume.
Strange so it may seem but perhaps this has happened to someone else that has an explanation.
Only difference between the jack and main speaker is the jack and a 470 ohm resistor. All componets have been checked thoroughly and are as per the schematic
thanks
in advance
cheers
thanks
in advance
cheers
