Hello,
I am having issues with constant beeping with the ace 150
Anything after 2 sensitivity makes it malfunction and cycle/beep through all tones
Troubleshooting performed;
-Check coil connection is secure
-Wrap coil lead tightly
-Clean coil & coil cover of loose material
-Replace batteries
-Checked batteries are fitted correctly
-Test away from anything metal
-Tested another coil (Factory ACE 150 coil)
-Tested coil in free air (not attached to pole)
-Factory reset device
-Took apart control box, ensured the battery compartment springs were making contact, ensured no components were lose
-Set potentiometers to lowest sensitivity and tested. Would not pickup metal on sens on 1, but once changed to 2 it would go crazy again
Any help is appreciated thanks!
Here is a video of how it reacts;
https://www.youtube.com/watch?v=XYDl...ature=youtu.be
-Replace batteries
