QUASAR AVR SMD version build
  • #61
    Can you explain to me how to build the coil for this detector and if you had technical documents for it.
    • #62
      look a page of Andy
      http://fandy.ucoz.org/publ/metallois...m_quot/2-1-0-5
      • #63
        I know this page but what I want to find, is the documentation that is show in this video.
        https://www.youtube.com/watch?v=HCq3m1dPfOA
        thanks
        • #64
          Repto, any progress?
          I was make it work in the bench with 12v accu batt, but when i use 3s 3 x li-ion battery, the ballance is gone and the device is useless, what is this???
          • #65
            @ ripsdevala
            can you post the link for shematic?
            Marc
            • #66
              At last, someone with interest
              http://fandy.hut2.ru/Quasar/Quasar.pdf
              I use dip version though.
              • #67
                I've not been there for a while.
                If you tune the detector on the bench and then, you put it in case with a different supply, it won't work.
                You should tune it with the final assembly.
                Do you use a ballance board for your lithium battery ?
                If no, you should think using one.
                My unit still gets hot on TX circuit. I'm bored troubleshooting it so, i do other things for some days.
                • #68
                  Im usig 3S ballancing, its already ok now, i drill the epoxy and do a tuning, but with concentric i only got 25cm
                  • #69
                    One more thing, im not use resonance capacitor in the coil, when i use it, the deep is very low.... Im not sure why
                    • #70
                      https://reibert.info/threads/plata-k....841906/page-2
                      price for board 7usd
                      uchip programmed 6usd
                      • #71
                        Originally posted by Bayu
                        hello master i got a quasar arm pcb from my friend but i don't have the quasar file,schema and data, can you help me to get it all?  Thank you very much
                        Quasar-F3? on this site https://fandy.ucoz.org/publ/metalloi...sar_f3/2-1-0-8
                        • #72
                          Thankyou
                          • #73
                            hi kt315, can the quasar arm use coil goldfinder sniper dia11cm TX=760uH and RX=8800uH, when I plug it in it can detect but the 2gram gold ring is only 5cm away, is there a solution? please help
