1.Tests for integral possibilities ( surface elimination ) –detector must have good sensitivity for deep buried targets and very low sensitivity for small targets ,positioned shallow in the soil ( eliminating garbage from the surface layer ). Very low sensitivity to slag is desirable.
2.Test for sensitivity depending of the kind of metal of registered object (difference in sensitivity to targets with the same area , but made of different metals ).
3.Test for sensitivity of coins ,placed in ceramic ( plastic or glass ) pot . 4.Test ,,scanning zone “-the size of the area is under the detector sensor system , in which the reaction to the target varies from about 70% to 100% (width of the searched path, trail )
5.Test ,, double signals “ ( duplicate signals ) . In close proximity to detector sensor system most targets give double signals .
6.Vertical buried objects -the difference in reaction of detector to orientation to sensor system of the detector of oblong targets (shovel, mattock ) .
7.Test ,,ground noises “. Strengt of detector's response , when changing the soil type . we have the following passages ( transitions ) :
- soil –ceramic –soil
-soil –mineralized stone ( hot rock ) –soil
-soil-limestone –soil
-dry soil-wet soil- dry soil
- Ergonomics and weight .
- Discrimination . This option is not very important in this class of detectors , although some developments on TX-RX detectors have the ability to recognition the iron objects .
