Original Surf P.I.
  • Original Surf P.I.
    Hello,
    I have some questions regarding this detector.
    - where is dumping resistor for the coil? It does not seem to be inside the shrink tube. Coil inductance (pulse diver 950) measure 0.224mh (hi reading) and 292uh(low)- which one is the real value? (i don't have multimeter with me to check the resistance).
    - can i use instead of 8AA battery's 3x18650? what it will be the drawback?
    - i have the black o-ring for the case, i've heard that is notorious for leakage. Where can i get the orange one in Eu.
    - what minus have in front of surf P.I pro?
    Thank you!
    - disconnect the coil and measure R on a board coil socket
    - write us the value
    schematic clearly shows - dumping R is on the board.
      How about a few side view pictures, so we can verify some of the resistor values?.
        I found the dumping resistor, is 220ohm but looks like is only 0.5w. why?
          can you send me the board for desoldering and give to people new project?
            The detector is fully functional KT. And there is a schematic on the forum with it.
              its OK. i need the board (layout). can you desolder it and share both side scanned? also Part List.
              Yours
                Yours
                I don't have time for such a thing. Part list you can take it from this schematic, is exactly the same.
                  sorry i do not need in the schematics. i have 4 Gigabites archive with that and more than that.
                  NO INFO outside i need.
                  with your pcb back i send you a pcb or on delta pulse, either King Cobra, either Barracuda. on your choice.
                  you will get your pcb tested and resoldered back.
                    not interested in this kind of deal, sorry.
                      you are surfprojectkiller LOL!
