i have made my own blue tooth headphones using ear defenders...very comfortable on the ears...works ok even without low latency blue tooth transmitter.
HOME MADE BLUE TOOTH HEADPHONES
Good job.
It's funy cause i did exactly the same thing for my job (work on plane).
Yours is as my first prototype.
My last one does not have cable for right ear. I use the metal of the bracket to make the signal transitting.
The usb cable is hided in the ear. I'll post a picture later.
I wanted to use it for home made detector but each time i buy BT transmitters from China, i receive receivers !!!
i got sick of buying BT stuff allways a delay and it never shows you on the box
https://www.tesco.com/direct/kitsoun...?source=others
last crap i bought
Originally posted by kosacid View Posti got sick of buying BT stuff allways a delay and it never shows you on the box
last crap i bought
BT version 4.1 is what you need, but not all BT devices are created equal and not all "pair"
Originally posted by daverave View Posti also have an old turtle beach gaming blue tooth headset which work really well with metal detectors....i also use sometimes a blue tooth amplified water proof speaker which also works well with metal detectors.
