Garrett TR with constant audio signal
  • Garrett TR with constant audio signal
    I am troubleshooting this late 1980's ? Garrett TR/Discriminator detector with a constant audio tone.
    Cannot be tuned by depressing the tune button and adjusting the tune control as you would normally.
    I have a good Tx signal of 62.5khz with 11 v p-p on the Tx coil. When a 2" square of foil is placed on the search coil, I have a good Rx signal of 62.5 khz 3.5v p-p
    Circuit uses 6 transistors, one FET, two dual op amps, one dual voltage comparator, one quad switch, and one single op amp.
    I am presently drawing out the circuit, but wanted to know if anyone here would know what triggers the audio to the speaker?
    Re: Garrett TR with constant audio signal
    Have tracked down the problem to a missing signal voltage from the Rx because of a bad 4016 bilateral switch.
      Judging on your description it could be a detector described in patent:
      US4303879 Metal Detector Circuit with Mode Selection and Automatic Tuning
      or
      US4334191 Metal Detector Circuit Having Momentary Disabled Output
      Both available at geotech, I believe.
      have fun,
      Peter
