Hi Everyone!
After lurking here for a while trying to find a solution, and hammering at this until 5am this morning I've decided I need to swallow my pride and finally ask the pros for help.
I've built the Surf PI from silverdog - everything's come together very nicely and seems to be functioning as it should be except for one part - everything's pulsing correctly on the scope and I can see some very clear changes in the returned waveform when I wave anything near the coil - however something just seems to be completely wrong with the balance/offset, and I just can NOT get the opamp to output any useful voltages - the signal at the input is far, far stronger than the opamp output!
With R11 and the 100K pot in place I cannot pull the offset down to 0 - on a scope or multimeter. Removing the pot completely has negligible effect. Turning the offset pot seems to have near zero effect, and I can only get an extremely feint resonse from the NE5534. It sits at around 600mv, with very feint, small spikes where the pulses should be appearing.
All resistors have been checked, all capacitors, transistors, IC's and pots have been replaced; I've cleaned the board down with alcohol and checked for shorts and cold joints with an illuminated jewellers loupe, despite having over 20 years of soldering/EE experience... I've constructed the variable damping resistor and got it spot on.... I'm now at my wits end and almost pulled out all my hair. The opamp is definitely seeing the input OK - with the scope on pin 1 (BAL), there's a sawtooth waveform which heavily modifies towards square when metal approaches the coil. What this signal actually is, I have no idea as the datasheet doesn't say - but it's showing me that there's a definite, very strong response to bringing metal near the coil. The coil measures about 320uH and is in a rounded-rectangle form. Same effect with a flat coil and round coil. I've used all these test coils very successfully on a home-baked arduino-based PI circuit.
The absolutely wierd thing however, is that I've got it working backwards!? By placing an 8n4 capacitor between the output (6) and COMP/BAL( 8 ), it sounds constantly, and then goes silent when I bring a coin near. when removing the coin, it sings a little 'wooooo' and then goes back to constant tone. Every video and demonstration I've seen has the detector usually silent and it sings when metal is near, and it seems like I've unwittingly enabled a pseudo "motion" mode for this detector.
I'm achieving a free-air range of around ~5 inches on a 925 Aussie shilling, ~8 inches on an aussie 20c coin, ~4 inches on a 10c coin, around 1 inch on a computer screw, and a 1.5kg Fire extinguisher at 1.5 foot.
If anyone has any ideas which could help me get this thing performing normally, I'd really appreciate your help... While it does seem to be functioning in a way, I'd prefer it not to be such a hackjob (as a software developer I disdain 'hacky patches' like this!)... If you want any voltage readouts or pictures from my (crappy el cheapo) scope, let me know and I'll take some for you. If you want videos to see how it behaves I can do that too. Happy to answer any questions anyone may have which could get me closer to a solution.
Thanks in advance to anyone who might be able to lend some insight!
Mark
Mark
