What's a good PI kit for finding large objects
  • What's a good PI kit for finding large objects
    I'm looking to hunt caches, what's a good PI kit to use? I'm looking to use a large coil, 36" x36" or larger, to discriminate out small trash, Carl told me to swap a resistor out to slow the SAT speed way down for this kind of search, do you all have any recommendations? Thank you
    Almost any of the PI detectors will work.
    Basically look for one that has adjustments of TX pulse, Sample delay and SAT speed so you can optimize timing for the coil and targets.
    The Hammer Head does have these adjustments so take a look at that one.
      Delta Pulse is a deeper and works with big coil. also DP has advanced true SAT.
        Waltr, does the Hammerhead PI have a knob that adjusts SAT speed?
          Hammerhead PI is best PI having perfect detailed report kinda 'how to do the thing if you are beginner in electronics'.
          this stamp for mouse pad and you can have it under your hand working on PC.
            Yes, Check the schematic
