I'm using DxO Optics Pro 8 to modify photography, I'm going to analyze individual programs over the weekend - and I'm trying to do a screen scan.
Minelab Equinox Challenge
Originally posted by EL NINO View Postthe frequency values are slightly different in a small range depending on the type of multi-frequency programs.[ATTACH]44934[/ATTACH][ATTACH]44935[/ATTACH]
Good stuff though.
You can also use "Alt" and PrtScn to just capture the active window, and miss out your desktop background etc. It may be useful, a bit.
And as mentioned , there's a new thingy called 'snipping' that is included with the newer Windows versions.
Originally posted by EL NINO View PostIvconic..I tried a snipping tool and that's ok ..
Every once in a while i "discover" all over again that nice and neat Windows component.
Crazy.
Because on each new Win installation i also do install SnagIt as my default tool for screen&area grabbing.
But i also do use Snipping Tool too... when i recall that it exist on system!
Originally posted by EL NINO View PostBeach2 [ATTACH]44961[/ATTACH]
Beach 2 -in overload [ATTACH]44962[/ATTACH]
Gold 1 [ATTACH]44963[/ATTACH]
Gold 2 [ATTACH]44964[/ATTACH]
Gold 2 -20khz[ATTACH]44965[/ATTACH]
Gold 2-40khz [ATTACH]44966[/ATTACH]
Do you have 192kHz sample rate as an option, Nino ?
Do you think it will make any real difference to the spectrum analysis ? At 96k sample/sec, he's (just) sampling more than two samples per cycle of the highest freq of interest, 40kHz.
Originally posted by Carl-NC View PostEl Nino, you're sample rate is too low to capture these signals at decent resolution..... .... my laptop's sound card - it allows sampling up to 96 000 Hz / 24 bit, and in the VA program alone -mam set-up up to 96000 Hz / 32500 FFT-24bit ..so I'll have to buy better an external sound card...or new laptop..
Originally posted by Skippy View PostDo you have 192kHz sample rate as an option, Nino ?
