Best DIY detector for gold on beach (wet sand and few seawater) in volcano soil
    https://www.youtube.com/watch?v=qqDNQno_MRM
    Quasar LCD menu
      Originally posted by qute1 View Post
      kt315 is well known for his "humour" which is sometimes lost in translation (northern european languages lose something in translation like with german) he means nothing by it so please do not take offence as he is very knowledgeable when he chooses to share.
      As to coils if you wish to use it on a "cane" or stem as per most commercials and on the beach i would go for around 10" as there are many 9.8" polo housings available and is also the same size as those big plastic paint container lids if you need to fabricate a housing yourself (two stuck together with the coil in between is quite acceptable both practically and aesthetically.
      there is either people want good detector kit or they want see only 'humour', offencive, and that i am aggresive. thats their right.
      what people want see is they see.
        Felezjoo and chance have no "screen" indeed but they do give different audio tones for different returns and you can learn them with your ears also i believe the crazytech discrimination module and similar can be fitted (to the felezjoo) but i have no actual experience with other than zr71.
          humour is relative!
            Thanks for information.
            I am delighted to know this forum because it is technical and there are many competent people. I am here to learn and thank you for helping me.
            I have been prospecting for years with an analog VLF golden mask 1+ bi-ton. I do not have a screen but discrimination allows me to easily eliminate ferrous and multi-tone give me an idea of ​​the buried ferrous iron.
            People I know use impulse detectors like the SCOPE CS4PI and complain about having to dig through all the sounds, that it has trouble finding small objects and gold. They also complain of low performance (15 cm maximum for gold jewelry)
            Seeing videos on the internet and kits on ebay I saw that it was possible to discriminate the ferrous with the impulse.
            I wanted to have confirmation from a specialist like you that it was possible to:
            - Discriminate with a multion tone, VCo or a mon-ton that cuts the ferrous
            - That the proposed kits will be able to capture small gold targets at least 20 cm in salt water or wet sand.
            KT315 I do not focus on the screens but it's the only ones I saw allowing to discriminate or recognize the targets thanks to the ID. If there are multi-tone or monoton to discriminate ferrous without forgetting the gold I'll be delighted to know them.
            What models do you recommend for my use without necessarily having a screen?
            PS: i have found Fortune M3 https://www.ebay.fr/itm/Metal-Detect...h/222810485615
            Thank you
              Gold chains are a tough target for a PI. It's seen as individual links. It's normally only the clasp that's detectable. Same with stud earrings. The Baracuda would certainly struggle with a fine ladies gold chain.
                Thanks.
                Crazy-TECH say "XR-71 is slow motion detector and generaly it is for bigger targets on high depth."
                I hesitate between CHANCE and felezjoo. But i think i will test felezjoo.
                  Originally posted by gandolfi View Post
                  Thanks.
                  Build them both then you can compare in real life.
                    i have a batch of bara boards. 12euro for 1. begin from simplest project.
                      thanks. Baraccuda have audio discrimination for ferrous or recognize target with sound ?
                        all PIs has NOT the disc like you wait from VLFs. if you hope felecjooo has... that is only your deeply delusion.
                          i don't understand.
                          The video are false ? Chance an Felezjoo can't recognize target with sound or ID ?
                          another member advised me these models for the recognition of targets
                            chance and felezjoo WILL give an indication of the type of target but you need to learn the tones. As i stated before discrimination like with vlfs is not a reality with pi but vlf DO NOT WORK on the beach or in the surf as you asked for.
                              ok. i m reassured. need to learn tones is ok for me. it's a language mistake when I use the word "discrimination"
                              I am trying to find out or take the felezjoo. If it's easy to solder and set it alone.
                              Little shop sells it
                                where is a link on the video? i do not see.
