what ic i could use instead of reg1117a
  • what ic i could use instead of reg1117a
    what ic i could use instead of reg1117a -Carl's pi metaldetector?
    reg 1117
    Use an ordinary Lm2940ct-5 ( yes 5 volt!) but put a 5,6 v zener in the commen lead of the LDO. The current through this lead wil bias the zener. You wil get a nice 10.6 volt with a input voltage difference of only .2 volt. Use a capacitor of 22 uf at its output. Be aware that the leads of both divices are numbered differently!!
    rergards; Lki
      reg1117
      You can use an LT1054... just plugs straight in no mods or anything.
      cheers
      gef
        The lt1054 is nice because you can use it up to 15vdc.
        RayNM
          Yes thats true.. I have used it a few times in different circuits and no problems with it.
          cheers
          gef
            Are you talking about the Hammer Head? I don't see a reg1117a in the Hammer Head?
              Gary's Twin Coil
              REG1117A is used in "Gary's Twin Coil PI" (also called Pulse-2).
                Thank you.
