TROY SHADOW X5 HELP
  • TROY SHADOW X5 HELP
    i have just resoldered the coil connector for someone i know and i did a resistance check on the TX/RX coil connections and im getting a reading of about 4 ohms on one and about 45 ohms on the other...is this correct ??? as im not sure if the two screening connections are the correct way around.
    right screening connection is all wires connecting in one point near to preamp. this is rule of right screening connection choice.
        Artiomuuushkaaa... take a clip from Global Coils Database and you will be happy. ahaha!
        Troy Shadow
        Name TX-L TX-R (ohms) TX-fo TX wire RX-L RX-R (ohms) RX-fo RX wire
        ________________________________________
        X2 S-9 9" 5.72mH 23.6 --- --- 6.25mH 25.2 --- ---
        X5 7" 1.067mH 4.33 --- --- 6.53mH 32.2 --- ---
        X5 9" 1.044mH 4.45 --- --- 6.50mH 32.7 ---
        X5 1.1mH / selfres = 255kHz 6.5mH / selfres = 87kHz
            for deep searching of any VLF coil i released especial coil tester. you can use and get data. inform and i will fill the database.
              its ok now all sorted
