Surf PI Micro Var. 1.00
  • #91
    Ah, now I see that there is an smd pcb version, which is why the schematic shows BAV99
    http://smartelectronix.biz/publ/obno...micro/1-1-0-79
    • #92
      Somewhat confusing with the diodes I find.
      These -5V are tapped at the driver stage for the mosfet
      Somebody should write something that has already built this device
      • #93
        https://m.youtube.com/watch?v=akBC8-...ature=youtu.be
        https://m.youtube.com/watch?v=IWbO_VDvZwo
        • #94
          Are you sure that this is the same circuit? I cant see a second 14 pin IC on the board.
          I flipped my diode and i got -5V without coil. But the detector still does not work.
          I dont have negative voltage with coil and without mosfet.
          I need to check the other chips.
          • #95
            Are the transistors properly polarized?
            to the Videos " As the bell rings the maypole spins "
            • #96
              I dont exactly know what you mean with polarized. I can measure 0,64kHz at the Mosfet Gate to GND, so i think they are ok.
              I also know that the one for the speaker is ok because i can hear the sound.
              My microcontroller sound is not the same as the one in the videos.
              Problem is that i only have 1,5V negative voltage with connected coil.
              I also get a steady tone which disappears when i touch the MOSFET. (without coil)
              I also forgot to check the MOSFET before i soldered it in.
              • #97
                Check your PCB track at MOSFET between drain and source, the space is very narrow, make sure it's not shorted. Even with coil connected, with MOSFET removed, you should get -5V.
                • #98
                  Also check diodes D4,D5 raising off one leg and checking with meter.
                  You must have -5V with everything connected.
                  • #99
                    I saw that i dont always have 640Hz pulse.
                    I think thats why i had 1,5 Volts.
                    When i have pulse the everything looks fine (with coil connected, without mosfet)
                    Voltages are ok.
                    So i decided to put OP1 back in.
                    I get -8V negative and 11V positive voltage when i insert OP1 (NE5534) , i used a new one for this test.
                    I cant test the pulse with my DSO i think i got a faulty one, i can not adjust the picture and it doesnt work always.
                    • What is the voltage at the gate of the mosfet, what is the signal at the gate?
                      Personally, I do not like this driver stage for the gate, and it's oversized
                      • 22,28 Volts at the Gate without MOSFET and 0.64kHz
                        • Sorry to say, but it appears that you are going around in circles.
                          The project definitely works.
                          http://vrtp.ru/index.php?showtopic=19745&st=780
                          Here is discussion of Eddy' project. The entire thread is dedicated to surf pi, including microcontroller version.
                          Use chrome browser for translation to English.
                          • https://www.vishay.com/docs/91084/sihf9630.pdf
                            I agree with dbanner
                            • The voltages are always different and sometimes the pic works and sometimes not without pulse.
                              I think i will put the pcb aside for now.
                              Thanks for the help.
                              • One more thing, there was a small error with the silkscreen for D2, so you have to assume that there could be other small discrepancies. I would check over the pcb, comparing it to the schematic. Make sure everything checks out OK.
                                Maybe I will try to make it myself, I think it is nice little project.
