Originally posted by BKY1337
Anyways, 640 Hz pulse sounds like surf prf. So that's good. It means the pic is programmed successfully.
I won't bother asking you how you managed to get 22voltz out of 8AAA batteries.
You should really use simple laptop scope software to see pulses from pic. If you don't have proper scope then why not. Frequency is low enough for soundcard on PC. Just don't connect anywhere near to coil or MOSFET. You may need this for adjustments for samples 1 and 2 when you finally get circuit up and running. If you have oscilloscope then disregard last comment
