As Carl has mentioned before:
Response conductivity is due to target metal type.
Response inductivity is due to target thickness.
Response strength is due to target surface area.
Which means that the inductance is mostly controlled by the skin effect (which depends on target thickness), and resistance is mainly controlled by the conductivity. Both target size and shape have an effect on the inductance and resistance. Therefore, although you only need to have the correct value of tau for modelling purposes, the problem is essentially a matter of figuring out what the tau needs to be. Which is why you'll not see any hard-and-fast numbers published anywhere.
(posted in another thread)
I've been thinking different:
Response conductivity is target metal type and target thickness
Response inductivity is size, width and length mainly width(maybe only width)
Response strength is due to surface area
Have read in some of the replies skin effect effects thin targets not thick targets. When I search skin effect, current isn't the same thru out target thickness(higher on the outside). Been thinking if target charts straight line decay linear log chart, target not effected by skin effect. If decay isn't straight line decay, faster decay in the beginning its because of skin effect.
Including some charts with examples.
TRT_29: Stacked foil targets chart straight line decay, not effected by skin effect. Slopes not the same so would effect detection depth.
Quarter and stacked quarters, not straight line decay, effected by skin effect. Chart straight line decay at longer delay times.>2 or three target TC's? Chart close to same at normal sample times so wouldn't effect detection depth.
TRT_32:second graph, copper clad board and lead sheet chart same(TC=(L/R)). 1oz copper clad board 1.4mils thick, for same resistance lead would need to be 16.7mils(measured 16mils, close enough)
Probably been discussed in other threads but I couldn't find what I was looking for so I'm starting a thread labeled skin effect. Maybe I'm thinking wrong or it's a matter of definition.
