Have seen the statement posted in some threads. Been wondering what I would need to get my PI detector to detect a cola can at 2 meters. I can detect a cola can about 3/4 meters, 20cm coil with 1A peak Tx current. To detect at 2 meters I would need to increase S/N 360 times, to detect 5 meters increase S/N 88000 times. Some questions. Does 3/4 meters with 20cm coil at 1A peak current seem reasonable or should it be a lot greater distance? Does the math make sense? What can I try to increase signal other than increasing coil diameter, coil inductance and peak current?
2-5 meters depth on a cola can
I've dug a few cans out at nearly a meter with an IDX and a 10" coil.
No fun and a waste of time. Doesn't take too many to ruin a days detecting. 8" coil is much better. You loose no depth on small targets but doesn't pick up those deep cans.
Why anyone would choose to detect beyond a meter makes no sense to me here in the UK. Unless you like collecting bits of farm machinery.
Originally posted by Koala View Postincrease coil size. 20 cm less than 8". Try 15" coil if you want to search for cans ?
just tried a F1265X with an 8" coil and a vimto can. Maxes out at 60 cm and nice tone to 55 cm
Guys, one meter is around 3 foot deep. Two meters is 6 feet, 5 meters is 15 feet. I was a metal detector dealer in the past, and I knew of NO machine that would detect a small can such as a cola can that deep. Only the LORD GOD can find a cola can that deep. Now you can fool with the detector, and fool with the coil, and you might achieve the depth of 3 foot deep. But not 6 foot to 15 feet deep.......
Melbeta
