Could someone tell me about the details of Self Adjusting Threshold (SAT) and what is the benefit about it? I am searching it online and I find it is related to the motion mode of the metal detector but I still cannot figure it out. Thanks for the help.
what is Self Adjusting Threshold
Originally posted by DJSUOL View PostThanks for your reply. Could you please tell me about that why the coil with a specific inductance such as 400uH is chosen for a better performance? What is the influence of the inductance to the performance?
Originally posted by DJSUOL View PostCould you please tell me where I can find the details about this part? I could not find the details to introduce the related circuit design from the Internet
SAT circuit?
Look at many of the common PI detector schematics for the SAT circuit. The Hammer Head is a good one.
You use LTSpice----- Simulate JUST the SAT circuit and inject with a single pulse.
Sorry I am a little confused now. For example, in the surf PI design, the DC voltage from the integrator is directly fed into a high-pass filter, why the DC signal is not blocked by it? Is it because that the output of integrator is still an AC signal and the time constant for the high-pass filter is larger than the integrator? In addition, when a target is present, the output of integrator will increase so the change could be fed to the final gain stage. If the metal detector keeps detecting the same target, the output from the integrator will remain steady so the voltage will become the value before. Am I right? Thanks for your explanation.
