The Disc and GEB adjustments will be done in demodulated baseband. These phase shifters need to prepare a adjusted ~45 degree shift, and 90 degree shift on top of it, do that I can feed the CD4052 (or better, but with the same control arrangement). This way I'll get I+, I-, Q+, and Q- outputs, adjusted so that Q is precisely 0V when ferrite is used as a test target. This way I'll have fixed phases for VDI, while DISC and GEB adjustments will not depend upon the frequency or a coil.
In short, when you replace a coil, the only thing to set is a 45 degree adjustment, and you are good to go.
