Help on vlf circuit
  • Help on vlf circuit
    Was a circuit posted a year ago or so,simple vlf.Does anyone have more information like pcb photo,frequency,pin #s,IB?.Was posted on page 14 of this forum. Thank-you Gene
    Re: Help on vlf circuit
    Is this the one you want?
    Click Here
      I believe it was this one below .
        I can do PCB layout in Eagle, but question is:
        is it real working schema?
          Yes - it really work. I made copy from original PCB and used original search head. But it was unstable at high temperatures (above 35 C). Transmit frequency is around 15 kHz.
            Hi Ned,
            what is the name of the VLF detector?
            Chris
              No name - it is hobbyst work. I suppose that it can be improved in many aspects.
              BTW sensivity with DD search head, each 18 sm is great - 1.8 sm coin at 28 sm in ground.
                This is one of Bulgarian famous "REBEKS", designed by Grozdiu Grozdev from Varna. The original have had "8" search head!
                More information you could receive via [email protected]!
                Good luck!
                G.Gueorguiev
                  It's not absolutely true. I have the original circuit designed by Grozdiu (Grozdanka)and there are few similarities between this one and the original. Most significant difference is in sinchronous demodulator. Grozdiu used for this small transformers, diodes and capacitors, where this design is based on 4011 and 4066 IC's.
                    Hi Ned
                    Can you post the orginal circuit design by Grozdiu into the forum? I'm sure in the forum are many who are interested and want to have a look at the original design, like me.
                    Chris
                      OK, but first I should redraw it - it will take take up some time.
