WHITES METAL DETECTOR DEEPER BEEPER
  • WHITES METAL DETECTOR DEEPER BEEPER
    Hi to all do anyone have circuit for this unit?
    Look in the US Patent and Tradeark Office
    Go to the Patent search page and enter the following inventor name: "David Bernzweig". He is the inventor of the DepthMaster which I believe is similar to the Deeper Beeper.
    The DepthMaster does three things:
    1. Provides a better match between your headphones and teh metal detector audio output circuit. Most detctors use a 200 to 300 ohm resistor between the speaker and the headphone jack to reduce the volume. This causes lowe impedance headphones to loose some efficiency. The Dephmaster has a 1000 ohm input impedance and is a better match to lower impedance headphones help hear the deep ones.
    2. It is an amplifier as it uses a single transistor and a 1.5V A battery.
    3. It is a limiter to amplify the weak signals but clip or limit the loud signals. Since it only uses a single 1.5V battery, it can't get very loud.
    Look up his patent and you will see the schematic of this very simple DepthMaster
    circuit.
    The only down side to this is the loss of some dynamic range which tells you how deep something is. A way around this would be to build the Depthamster circuit with a full audio bypass switch using a DPDT toggle or push button switch. This way when you find a target just bypass the Depthmaster and hear the full unaltered signal dynamics.
    I use this on the beach to squeeze the last inch or two of additional depth out of hearing the "deeeeeep ones" when the pickings start getting thin for more shallow targets.
    bbsailor
      Re: Look in the US Patent and Tradeark Office
      Hi BBsailor
      thanks on the hit at the US patent server. I tried to search for the patent but I couldn't find anything under inventor name "David Bernzweig". What is the patent number?
      Chris
        Two numbers related to metal detectors are referenced on the search: 4,644,290 and 4,594,559.
        The text of one is provided below.
        I hope this helps?
        bbsailor
        Metal detector audio amplifier
        Abstract
        An accessory device for use with a metal detector with means to amplify the low, barely audible audio output of the metal detector so that it can be easily heard with further means to dampen louder audio output signals causing those signals to be softer.
        Inventors: Bernzweig; David S. (24 Raleigh Rd., Framingham, MA 01701)
        Appl. No.: 531295
        Filed: September 12, 1983
        Current U.S. Class: 330/149; 324/329
        Intern'l Class: H03F 001/26; G01V 003/11
        Field of Search: 324/326,327,328,329 307/559 328/171 330/278,284,149
        References Cited [Referenced By]
        U.S. Patent Documents
        4376267 Mar., 1963 Chu et al. 330/284.
        4486712 Dec., 1984 Weber 324/329.
        Primary Examiner: Mullins; James B.
        Assistant Examiner: Wan; G.
        Attorney, Agent or Firm: Nitkin; William
        Claims
        I claim:
        1. An accessory device for use with a metal detector of the type using earphones, said device being connected to the audio output of said metal detector comprising:
        means to amplify low audio signals from said audio output to easily audible levels;
        means to dampen loud signals causing those signals to be softer, said device including:
        a casing;
        means to releasably attach said casing to said metal detector;
        a first cable means to attach to said audio output and carry said signal to said casing;
        an electronic circuit within said casing including:
        an input having a first input line and second input line extending therefrom, said input lines being interconnected by said first cable means to said audio output;
        a transistor having a base, emitter and collector;
        said first input line extending to the base of said transistor;
        said second input line extending to the emitter of said transistor;
        a capacitor on said first input line between said input and the base of said transistor;
        a first resistor, one end of which is attached to said first input line between said capacitor and said input and the second end of which is attached to said second input line between said transistor's emitter and said input;
        a feedback loop with a second resistor thereon extending from said transistor's collector and said first input line between said capacitor and the base of said transistor;
        a power source such as a 1.5 volt battery on said second input line;
        a ground between said power source and said first resistor on said second input line;
        a line interconnecting said transistor's emitter to said ground;
        a first output line extending from said transistor's collector;
        a second output line extending from said power source;
        said means for dampening loud signals including:
        a diode having its first end connected to said first output line and its second end connected to said second output line; and
        a second cable means attaching said first and second output lines to said earphones.
        2. An accessory device for use with a metal detector of the type using earphones to improve the sensitivity tuning of said detector's coils, said device being connected to the audio output of said metal detector comprising:
        means to amplify low audio tuning signals from said audio output to an easily audible level to balance the coils in the search head including:
        a casing;
        a first resistor, one end of which is attached to said first input line between said capacitor and said input and the second side of which is attached to said second input line between said transistor's emitter and said input;
        a feedback loop wth a second resistor thereon extending from said transistor's collector and said first input line between said capacitor and the base of said transistor;
        a second output line extending from said power source; and
        Description
        BACKGROUND OF THE INVENTION
        1. Field of the Invention
        The device of this invention is in the area of metal detectors and more particularly relates to an accessory device for amplifying the low volume audible signals while dampening signals of above predetermined volume.
        2. History of the Prior Art
        Metal detectors used by individuals can emit an audible signal when their search coil passes over buried metal objects. When objects are near the surface, the metal detector produces a loud audible signal while objects that are more deeply buried will cause the detector to emit a softer, less audible signal. These less audible signals often represent more valuable objects such as older coins and artifacts. To hear these less audible signals better, the metal detector user will often use earphones connected to the metal detector which brings the audible signal close to the ear and blocks out other distracting sounds from the environment making it easier for the user to hear the softer signals. Unfortunately when detecting buried metal objects located close to the surface, the loud signal generated can then hurt the user's ears.Further, many times deeply buried objects cause the metal detector to produce an audible signal so soft that even with the aid of earphones, the signals are inaudible.
        SUMMARY OF THE INVENTION
        It is an object of this invention to provide an accessory amplifier for metal detectors which amplifies barely audible signals so that they can be easily heard and which also dampens loud signals so that they do not hurt the user's ears. The device is contained within a small casing which is attached to the metal detector. One method of attachment can be by the use of Velcro strips so that the amplifier is removable and reattachable. A coiled electric cable extends from the device and is plugged into the audio output jack of the detector. A second coil extends from the device to the earphones of the user. The device of this invention also acts effectively to increase the sensitivity of the metal detector because it increases the user's ability to tune the detector. Typical metal detectors have two wound coils in their search heads, each tuned to the other. A control knob allows the user to adjust the tuning by turning the audible sound created by the two coils down to just were it is no longer audible. If the sound is soft then it may be difficult to fine tune the detector as the tuning may not be perfect. With the signal amplified from the device of this invention, the coils can be perfectly balanced and the detector will operate with a higher sensitivity than if it were not perfectly tuned .
        BRIEF DESCRIPTION OF THE DRAWINGS
        FIG. 1 illustrates a metal detector in use with the device of this invention attached thereto.
        FIG. 2 is a schematic of the circuit of the device of this invention.
        DESCRIPTION OF THE PREFERRED EMBODIMENT(S)
        FIG. 1 illustrates an individual utilizing a metal detector 26 having the device 30 of this invention attached thereto. The device is interconnected to the metal detector by cable 32 with jack 34 inserted into the audio output of the detector. A second cable 36 extends from the device of this invention up to earphones 28. The device of this invention is small and lightweight, does not interfere at all with the use of the metal detector and, as mentioned above, can be attached to the detector by any removable and reattachable means such as by Velcro strips, snaps, slide clips or any equivalent method of fastening.
        FIG. 2 illustrates the circuitry of the device with cable 32 not shown to be attached to input 24 carrying the signals of metal detector 26 to input 24. First input line 42 extends from the input 24 to the base of transistor 14. Between input 24 and transistor 14 on line 42 is capacitor 12 which can be a 1NF electrolytic capacitor or equivalent. Before electrolytic capacitor 12 on line 42 and before the emitter of transistor 14, the first and second input lines are interconnected by resistor 10 which can be a 1K resistor or equivalent. Transistor 14 can be a 2N3906 transistor or equivalent. The collector of transistor 14 is interconnected by a feedback loop through resistor 16 which can be a 3.3K resistor or equivalent to first input line 42 between capacitor 12 and the base of transistor 14. On second input line 44 after resistor 10 is battery 20 which can be a 1.5 volt AA penlight batter. The emitter of transistor 14 is interconnected on the second input line 44 between resistor 10 and battery 20 which interconnection point 40 is grounded. First output line 46 extends from the collector of transistor 14 and second output line 48 extends from the negative pole of battery 20 between which output lines are interconnected diode 18 which can be a 1N34A germanium point contact diode or equivalent. After diode 18, output 22 is interconnected by a jack direct connection or equivalent means to cable 36 to carry the signal to earphones 28. The transistor and its related circuitry amplify the input signal while diode 18 acts as a sound dampener cutting off the amplitude of louder signals making their sound softer at the output while not effecting the amplified lower volume signals. When the device is not in use there is no power drain on the battery as the circuit only becomes operative when the earphone is plugged into the output jack or if the earphones have a direct connection, then when the input cable 32 is plugged into the metal detector.
        Although the present invention has been described with reference to particular embodiments, it will be apparent to those skilled in the art that variations and modifications can be substituted therefor without departing from the principles and spirit of the invention.
          4,644,290 and 4,594,559, PDFs for both are on this web site.
          - Carl
          P.S. -- Don't forget folks, you can't reply to postings via email, you have to post on the forum!
            Carl: Check these PDF files. I get an error when I load them.
            Carl,
            When I copy these file and a few other in the same Misc section, I get an Adobe PDF Reader error and I cannot open these files. I check other files on you patent section and they seem to work. I am using the Adobe PDF Reader Version 6.
            bbsailor
              Thanks....
              Thanks Carl,
              I found it.
              Chris
                Re: WHITES METAL DETECTOR DEEPER BEEPER
                sucker
                  TROLL AND LAMER ALERT!!
