Bounty Hunter QD-2
  • Bounty Hunter QD-2
    I have had a QD-2 since they came on to the market, an that was many years ago. I was wondering if any mod's or improvements to the machine have been posted on the web. Thank you for your time an letting me post on this board. Have great hunting, Jim
    None that I'm aware of.
      i do preamp coil board.. but that is winter melancholy matter, therefore slowly making.
      this preamp will be universal, for any type VLF coil. i think it will give 2-2.5" bit more on depth.
      kt315 flat pins
        The 11" x 7" DD coil for the Fisher F4 should fit it, if you get the correct connector. That might be worth looking out for, if the price is right.
          in BH used DIN type connector https://www.ebay.com/itm/DIN-Plug-Ma...j0T6iWpKfrB59g
            Yeah, that's what I meant. You need an early model F4 coil, with the DIN connector, not the later metal-body screw-on connector. Though it's an easy cheap job to change the connector.
