Need some enclosure ideas
  • Need some enclosure ideas
    I have had the Surf PI detector board in draw for years, it is long narrow type PC board. I tested the unit an it worked fine, now I think it time to finish the project. I would like some input from the board on a nice housing. I have the coil my homemade, basket weave , lenz wire. done, a nice "S" rod handle. So all need are some ideas. Thank you for the use of the board and Best to all, Jim
    I went with a plastic electrical junction box for my latest project. Cheap, available from every hardware store, and IP66 rated. Some of them look quite ok.
      The Surf PI board will go into a PVC tube which is then easy to water proof.
        i deleted some albums because them was much but maybe will put some again. look https://www.geotech1.com/forums/album.php?albumid=55
          Thank you all for the idea's, now just to back to shop a finish the project. Best to all Jim
