There are a few selectable frequency detectors on the market, I was wondering what the optimum ratio between frequencies would be to see a marked change.
For example if you had a detector set on 4.6khz I am guessing you would not see much difference in response until at least double, so about 9.2khz then 18.4khz?
Or as the frequency increases would the ratio be less than double?
I appreciated you have to factor in ground and EMI etc.
Thanks in advance
Thanks in advance
